why get an 80?
FRASER VALLEY,BC
I really love the hdj81's with the factory winch and lockers. But after looking into them a bit deeper I stumbled across all their problems (engine overhauls neeeded, fuel pump, BEBs, etc)
my budget cap is 15k, can I still get one for that, which isnt a POS? What kind of money will I be needing to pour into this?
I don't have any answers for your questions but nobody can answer you intelligently until they know where you live. FYI, the diseasel 80s were never imported to North America.
-B-
yeah where do you live?
If you live in Canada, where you can import these if they are a minimum 15 years old (That's what I did), go for it. Love mine to death. The biggest issue with the !HD-T seems to be the BEB. Do it yourself or get it done for around $700 I believe. It will save you a headache - if the BEB goes, good luck with the cost rebuilding the engine.
As for the $$ you have set out. You can get a half decent one for that, landed in Canada. If you want a perfect one, it is not enough. Mine was a 3.5B (true grade) at auction and landed and on the road for 14K (with BEB done). With all PM done probably just over what you are looking at cost wise. I have done a bunch of stuff I wanted as well (but not needed), so now definately above your budget. That's my 2 cents.
And yes, I love my HDJ81. It is great on the road and even better in the dirt and rocks. And the fuel mileage is better than an 80 with a gasser.
Brad
wow, sweet finally some good news. I live in BC so no problems there. Can you reccomend some reputable exporters? I dont care about the superficial stuff but I want one with low kms and no rust that is mechanically sound. What should I get fixed while its still in japan?
HDJ81 in Zambia
Why get an 80?
For me, the 1993 HDJ81 has been crazy unbelievable. Am not a motor-head nor mechanic. Don't know jack about most all of tech stuff. However, I've put nearly 30,000km on my rig that I imported from Japan about 14 months ago. It's not a DD so most of that is 30K Safari/expedition clicks.
The 15 yr old vehicle has taken me: 6,0009km through Kalahari, 3,535km through Chobe, Okavango, Mag Pans; 1,500km to South Luangwa - not to mention a dozen other trips - Lower Zambezi, Kafue National Park, etc etc etc.
Mods: see pic
OME (heavy on rear), African Outback 2.1m rack, BFG 285s, 70L aux tank.
Probs so far:
Alternator packed up (replaced). Steering box seems to have slight leak. I've asked several mechanics on the BEB issue here in Africa. They have 81s everywhere here, and no-one has ever seen the BEB issue. That's not to say it's not true...but that is the word from Africa.
More on rig adventures at: Life is never dull
c.
For African Bush, this 81 has been perfect thus far...knock on wood.
A cheap advice about the BEB if you don't want to spend the 700: keep your inyectors in good condition and replace the noozles if needed. Of course replacing BEB is safer, but sometimes it comes from a bad conditon injector.
Not many BEB issues in Spain as well, but quite a bit in England.
Another important thing: as the diesel has bigger torque, automatic transsmissions tend to fail more that petrol. It it's a auto, you should replace the transmission oil with a good synthetic oil and add an extra radiator if you do lots of off road.
I broke my transmission 1 day after buying my Land Cruiser. 4 months in the garage!
If you are going to tweak the diesel engine, I would also advice to get one of wholesale automatics extreme valve body kit.
Benston,
I'd suggest you post in the 24v/diesel section on 'Mud. Lots of local guys with diesel 81s are there, and you might even get a lead on one that's already here for sale.
As for me, I have had my HDJ81 for a 1 1/2 years, and love it. I imported mine and am into it for around what your budget is. My experience? No regrets!!! Would I import again? Hmmm... I think I'd look into the stuff that's already over here first. Though there's way more selection here now than when I bought my truck. If you have any more specific questions, PM me.
Good Luck!
lol, so THAT'S what the "D" in HDJ81 stands for...
Anyways man... It's probably going to be VERY HARD to find one in decent condition, with factory (or other) lockers for under $15,000... I haven't read about problems with the fuel pump, or about any engine overhauls needed, but I have read that the BEBs are prone to failure in these things (apparently $500 to replace, parts and labour inc., in the Lower Mainland (can probably cost less if you buy the bearings yourself (ACL sells them fairly cheap))...
I don't know if you consider the winch to be superficial but if you do, if you would be willing to stretch your budget $1800, and if you want one sooner rather than later, this one would probably be your best bet: 1992 Land Cruiser Turbo Diesel (and it's only a stone's throw away!!)
If you're looking for something lifted (again, not too sure what you consider to be superficial) you can take mine (1992 Toyota Land Cruiser VX Limited (lifted and on 35's)) off my hands for $12,750 (after the taxes and all that) :), but you'll have to change out the BEBs (~$500), install lockers ($2000+??), and change the tires in about a year ($800-$1500 if you want to replace them with 35's again). So right now you'd be over-budget $250-$1250, plus another $800-$1500 in a year (more if you need to do an "engine overhaul," or replace the fuel pump). The thing runs GREAT, is mechanically sound (I just had a mechanic take a look at it a couple of weeks ago), is rust free (except for a small area about .75cmx2.5cm on the rear-right window edge), and has only 93,000 kms on it... I can knock $100 off right away if you don't want the roof rack (again, I don't know what you would consider to be superficial), but that's about it...
Personally, I wouldn't but a vehicle if I couldn't test drive it first but if you test drive a few of them over here, and get a feel for them (just not mine), then it might not be a bad idea to import one that is in good shape (especially if you're not in a rush to get a new vehicle). Also, if you decide to import one I would only have the BEBs changed out in Japan (if it costs <50,000 Yen and they are replaced with decent bearings) and have the rest of the repairs done over here rather than in Japan (that way you can find out what NEEDS to be done rather than having someone replace/repair things that don't need to be repaired/replaced).
To my knowledge, you're not gonna find an HDJ81, in decent condition, with a factory winch and lockers anywhere in B.C. (at the moment). It you really want one with lockers for under $15,000 you're probably best off waiting for a really good deal to come along, or importing one yourself (in which case Toyota Landcruiser - Importing a Toyota Landcruiser from Japan to Canada might be able to help you out (they have access to some decent ones from time to time)).
These things are probably the best, most fuel efficient 4x4's on the road right now for under $20,000 but, unfortunately, it's highly unlikely that you're going to find what you described for under $15,000 (at least not locally). If you do then you can consider yourself very lucky.
Good luck in finding what you're looking for,
Rob
