I got my HIR's yesterday and my dome LED's today. I would suggest with the HIR's, if they are marked with white paint to cut them shorter than the markings since mine didn't want to fit until I did that.
With the LED install that I haven't exactly started yet since I don't have any silicone and don't want to use electrical tape, it looks to be simple enough if I can figure out how to get that personal/map light out. I've been having a problem with the rear cargo light(factory installed rear one). It comes on somethimes and sometimes it doesn't. I figured I had a bad ground so I took it apart after pulling the fuse. Everything looked good except maybe one of the wires in the plug looked like it might have been a little wide so I bent it in a little. Then I put every thing back together, put the fuse back in, opened the doors and saw the rear working fine but the front started to flicker then stayed on. It must have gotten jealous
. Time will tell if this fixed it and hopefully that front dome light flicker was just a fluke.
All the wiring looked well insulated, taped up and couldn't see anything wrong except for the wire inside the clip looked a little wide. Anybody had this problem?
