Who Has Mark's Speed. Correction Box?
Highlands Ranch, CO, Heart in AZ
Mark's Speedometer Correction Box
I received it as a gift, bought from Slee. Athough the physical installation looks straightforward after readng the distructions, it is very confusing to figure out how to calibrate it using the many dip switches. The instructions show no other way to me other than guessing what dip switches (16 of them) to flip on and off. I want to use my GPS which others have done. I searched with no success. It looks easy to calibrate it using a percentage or ratio of change based on old vs new tire size, but I want it exact. I know the approx. size of the stock 275/70, but want to use the GPS.
Has anyone installed one?
I have installed 2 Truespeeds on my Superduty trucks in the past and a knob was the only thing to turn instead of 8 or more switches in a row.
Drive the truck at 70mph on the speedo, read the GPS, calculate the % difference from the two speeds and then use the table in the instructions to locate the dip switch settings. They just list it as tires change, but you can do the same thing with the GPS vs Speedo readings.
Be careful the dip switches are not in order. Look at the numbers on the circuit board printing. They are interlaced.
An update: This is an extremely easy to install and calibrate speedo correction unit. In fact, you don't even need to drill a hole to route the wires to the speed sensor plug near the T-case. The hole is already there in the form of a factory rubber plug that you can drill or cut out. The plug is on the top of the tranny tunnel and you have just a few flaps of carpet to pull back. The unit will mount to the side and to the front on the center console. It will not get kicked by any feet, it is high enough.
Mark's box thru Slee is 100% plug 'n play and takes no more than 30 minutes to install and calibrate with the GPS. It may take less time if you are not running back inside to get :beer:.
Where on top of the tranny tunnnel is the preexisting hole? Is it for or aft of the gear selector?
I found one just forwards of the passenger side footwell air vent. Pull back the carpet a bit (no tools required) and have a quick look.
Does this do anything for the shift points or torque convertor lock up settings??
Do any of these wook for the fj80 1992s? I just made the switch to 5.29s with 35s. Would like to get one that can be adjusted for 33s in winter.:hhmm:
Yes, it returns everything back to stock for what I would think better tranny longevity.
Contact Slee and find out.
Another update: I recalibrated it once more due to the 5.29 gears being put in. Now I am only 1/2% off:D.
Guess i will be adding that to the list when I replace my tranny...thanks for the info...
So easy and works great. Option of 2 different sizes via a toggle switch for those of you that run 2 sets. I think it is a must for those not running stock since it is so easy to use and recalibrate for tire sizes or gear changes.
With a little help from a co-worker with a GPS, I just got mine dialed-in at lunchtime.
Works great, regardless of gearing/tires/etc. I've got 295's, 4.88's, and the Slee speedo correction gear (which makes the speedo effect from 4.88's even worse), and calibrating was a simple process of finding the ratio of actual speed to my speedo reading. Find the ratio (or one very close to it) on the list, set the switches accordingly, and bingo.
Awesome product. I am totally happy with mine. WAY better than splicing into ECU wiring IMO.
Adding to the thread for future reference including some pictures...The pictures might come in handy to others like me that didn't have a clue of where to look for the plug and 96r50's description of "just forwards of the passenger side footwell air vent" didn't sink in till I found it :hillbilly:
Apparently the box has changed because there aren't any dip switches now, just a couple buttons to push to change (+ or -) the ratio that shows up on the indicator.
On a scale of 1-10 this is a 1 :banana: install job but 10 :banana:s on the PITA scale IMO.
Maybe I missed something but threading the cable through the grommet and down to where it needs to be connected was simple...Disconnecting the OEM plug, plugging in the connectors from the box, and zip tying everthing up out of the way was a royal PITA. I STRONGLY recommend anyone that is regearing to go ahead and install the box and run the connectors while your front driveshaft is out...I seriously considered dropping my front shaft because it was nearly impossible to get my hand, let alone both hands, up to where the connector is.
If you are familiar with Toyota connectors, they can be a PITA to get apart when you can get two hands on them...Trying to do so with one hand and a pair of long angled needle nose pliers was frustrating to say the least. Then trying to do the one handed zip tie installation was :bang:....I envy you guys that completed this in 30 mins or less...
I'm still trying to figure out where to permanently mount the box...I was hoping it would be small enough to sort of sit above and toward the DS of the hole but it is too big. I need to find a spot where it won't get kicked by feet or other stuff crammed down in the PS floorboard.
The other thing I've noticed is that it takes a 1/2 block or so before the speedometer starts working? At first I thought I fubarred something but everytime I start up the truck it takes a 1/2 block or so before the speedometer comes to life :confused: - Anyone else notice this?
Pictures:
Sorry, next time I'll try and make it more complicated :p:D. Good idea with the pictures!
So this splices into the signal from the speed sensor in the transfer case at a connector on top of the transfer?
Do you notice any light surging sensation while using the cruise control now? I noticed a very minor accelerate-coast, accelerate-coast sensation after installing my Yellowbox. It doesn't show up on the gauges (speedo/tach) but I can feel it with the seat-o'-the-pants-meter. I'm not 100% certain that the Yellowbox caused it, but I'm curious to see if there is anything similar with this type of speedo correction.
:cheers:
No real "splicing" per say...Simply (assuming you can get your hands on the connector) disconnect the OEM plug and insert the Mark's box's connectors in between/inline. Zip tie everything up out of the way to keep it safe and away from the driveshaft.
I almost never use my cruise control and I haven't since install the Mark's box...I'll try to remember to give it a try and report back...
My only issue is the lag with the speedometer coming to life - consistently takes 1/2 a block or so before it starts working after each start up. Another guy in my club doesn't experience this but does experience a bouncing speedo needle when his rig first starts rolling :confused:
So...I tried my cruise control last night...Total of about 60 miles on the highway and I didn't notice anything at all resembling what you are experiencing...Just steay smooth @ 65mph - FWIW on the rare occasions I used my cruise control before installing the box it seemed steady, smooth, so no difference.
Spoke with Chriso at the meeting last night and he thinks the box may be defective causing the lag. Definitely not normal as far as he was concerned and he asked me to check the behavior with the switch in the other position ("B"). Same behavior. So, we'll swap out the box and go from there :steer:
no cruise control issues here.
Thanks for checking.
