white smoke...
Breckenridge, CO
I just finished getting my 2f swap wrapped up. I got it fired up let it run for a little bit. Burning off some spilled fluid from the headers. Then I realized that there was white smoke coming from between the fire wall and the back of the engine. Its a really tight fit and I couldn't get a good look with smoke in my face...
It was white smoke and smelled like coolant. So I'm guessing I'm leaking coolant somewhere. I didn't see any hoses that were leaking, not to mention there really arent any coolant hoses behind the engine. I havn't had a chance the drain the oil and check for coolant in the oil.
A friend suggested a blown head gasket or cracked block. My search on mud says a cruiser block is hard to crack. I'm thinking, cracked head, head gasket, or maybe a freeze plug? I just thought about freeze plugs, I don't see a reason why that would be it, or if there even is a freeze plug in the rear of the engine.
In short, I swapped in a used 2f, I never saw it run, took my time putting it in, finally got it fired up, white smoke flowing up from the back of the engine, how can I narrow down the problem?
plus I just found another 2f thats seized, waiting to find out more, possible head donor?
Or maybe I'll just go for a 2-fe
is there any subtleties I should look for, I'll be able to tell if its totally jacked. A little tweak might be hard to tell, its pretty hard to look between the engine and firewall...
I really hope its a freeze plug:doh:
go to the dollor store buy one of those cheep dentist mirrors like the ones they used to see if they are cleaning your teeth im sure somebody will have better advise than i do but this is where i would start
