I started puffing white smoke at low RPMs and vehicle ran hot so I shut it off. No issue with performance or rough idle. Drained the oil, no milkshake or coolant in it. Smoke doesn’t smell like coolant and stings the eyes which I’ve read is unburned diesel. Pin test showed code 32 and 35. I did take apart and clean the MAF sensor. Since then Ive had a long crank. Any thoughts on timing, stick injector, turbo issue?
