Whipped by the wind
Tucson, Arizona
i have a 73 fj40 with a Bestop bikini top and I am considering the soft full doors (the ones that let you convert to a half door). My question is for anyone that has these if they help reduce the wind fatigue at higher speeds. My last run just wiped me out after a 45 minute trip down the highway. I really don’t want to put the hard top on - living in Arizona I would need to do A/C and I would not have the wonderful open feeling of the cruiser
I typically run a bikini top and I sometimes run the 2-piece soft doors if it's raining heavily or snowing. The doors help a little, perhaps. What helps more is using a duster to keep the wind (and rain/snow) from curling back into the cab from behind. I also use foam earplugs and those help immensely. Without earplugs, the wind noise and popping of the bikini top will do damage to your ears as well as causing fatigue.
Careful with the foam plugs - you can get pulled over for wearing them since they block out so much sound and are usually bright colors so easy to spot. Get some discrete musician type plugs - they are harder to see and you can hear a better range and they definitely take the edge off.
