In reverse it is.
The transfer case whines a lot. You might be hearing that.
Good idea to check the fluid levels. The Cruiser trans/transfer has an issue with leaking between the units. One will go dry while the other fills up. Good to keep an eye on them. The transfer rear seal is also prone to leakage on high mileage units. Good idea to keep an eye on the fluid level if you have a leak
Synthetic gear oils can help to quiet down noisy gears and improve fuel mileage.
