I ve had a DT whine 40+++Mph that is driving me batz Really gets singin' on long trips.It's a torque only sound most obvious when when cruising.
I finally bit the bullet and let the local $80/hr indie trans shop look it over(Proo's in Jamesburg). They concluded using a listening device it was rear diff "fer sher" Had it rebuilt using TPI master kit and a grand or so later no change
noise/grind still there only now there is a "tap" from back when coasting 10 15 mph
almost like a rock stuck in a tire.....
So that would only leaves the TC as the only possible whiner.
Had TC then fully rebuilt using master kit from TPI also and another $1500 is down the rat hole with still no change in the noise I was sure would go the way of ethics in American politics
I did have the shop do the "no rear driveshaft" test and they did say it made the noise stop Heavier fluid in the TC made no change in sound.
I am really bummed &can ill afford these little "repairs": we get taxed and "child supported "to death these here parts.
The shop is stummped as to where the whine could be from
I had the shop in touch with Bob over at TPI for advice to no avail... This project is stuck in a ditch with no winch in sight.
Any help/ideas would be greatly appreciated
Thanks to all
D
Thanks to all
D
