So I smell a ton of gas - replaced all fuel lines and inspected the fuel sender gasket on my 74 FJ40 -- all fine now. The tank however - has a small hole in the base and one at a seam. I need a new one. I see CCOT has the poly tanks w sender and hose kit (looks like some 5/16 fuel line) for $178. The OEm tanks from SOR ect look like $$. Has anyone had one of these CCOT tanks and how did they work? Any install tips? I wil plan on flushing I guess - probably with water and then let dry for a day or so - if that sounds right. I cannot figure how the tank is held in place. I do not see any tank straps / shims. Are there some hidden bolts someplace down low in the 30 years of suff piles around the base? Thanks -- Matt
