which way to mount steering pump bracket
Quick question about installing the bracket for my power steering pump. I originally thought it want next to the valve cover, but after setting the bracket there, I don’t think that is where it goes. I have nothing to compare to so I need your help. Does it go on top or closer to the second picture, lower on the block?
Thanks,
Dan
Oh this is all on a 73 F, FJ40 engine block.
This way and if so how do I make it work?
Or this way and does anyone have a picture of one mounted.
The last one is of my relocation alternator bracket. I figure it goes on something like this and I need to move my winch solenoid.
The mount you are showing in the top three photos is an air pump bracket. It bolts to the block near the location shown in the 3rd photo, but needs to be turned so that the bracket mounting flange is horizontal (same orientation as shown in the 1st photo). On later blocks, there are bolt holes for the bracket directly under the motor mount (there is a groove below the motor mount that it slides into). I don't know about your block. Did it originally have an air pump? If it had an air pump, it should have the mounting holes for the bracket.
In the last photo, your positioning of the alternator bracket is correct . This is where it is mounted on later engines. Perhaps it is just the way it is photographed, but your battery seems to be in the way of the alternator bracket in this photo. Normally, there should be plenty of room to mount the bracket to the side of the block in that location.
I have to use that mount and modify it so it works with a power steering pump.
I understand that.
You use it in the same location for a power steering pump. It bolts into the original air pump mount holes in the block.
