Which tranny in a '93?
Buda, Texas
I've been lurking around for awhile and finally pulled the trigger on a '93 Cruiser so as a neophyte I need some advice or help. I got the LC for a good price. The bad economy had the seller highly motivated. What I know is that only synthetic Mobil1 was used as records indicate. I know the intervals of gear oil and tranny oil changes. What I don't know is the transmission filter change and the aftermarket transmission gasket isn't in the best shape. Appears that someone over-tightened the bolts and crushed the cork or syn-cork gasket. I want to replace the gasket and while I'm at it I'd like to replace the transmission filter since I don't know when it was last changed. Most of the aftermarket filters come with a gasket of some sort but Toyota recommends to only use silicon. What do most of y'all do? I went to NAPA and there are 2 filters. How do I determine if I have a A442F or A440L transmission without dropping the pan? Any advice is appreciated. I know, I know I"m a newbie so flame away, I can take it.
Jeff
You have the A442F tranny.
The filter is not replaced. You drop the pan, clean out the filter with some brake cleaner, and screw it back in. The pan does not use a cork gasket. You use the FIPG (Form In Place Gasket)...the red stuff.
Thanks Beno. That's helps out.
I thought the cork gasket was an aftermarket item. I'll clean up the filter and use the FIPG. Only had this '93 FZJ80 for a couple of weeks and I like it more than my 7/8ths '06 Tundra. I wish it had factory lockers but I couldn't pass on this one when I saw it for sale.
Double check by looking at the VIN plate, will tell you trans type
Unfortunately, NA vehicles--IIRC, starting with the 80 series--stopped having interior engine bay metal tags like this.
Most of this information was transferred to the USDS door/jamb area. It's a white tag that "cryptically" states the above information. It's written with small writing along the bottom of the sticker in the "fine print."
