Which radiator/heater hoses to replace?
Oregon
Website
www.brian894x4.com
Normally I do most of my own maintenance, but I’m taking my LC in to a dealer to have some minor stuff done to it that I just don’t have time to mess with right now, like a tranny and radiator flush. I was thinking, since the radiator will be empty, this would be a good time to replace certain radiator and heater hoses. I’m asking, because I’m fairly new to the LC and I’m not sure if there’s some hoses I can’t really see.
It only has ‘86K miles, but I’ll be traveling in some relatively remote areas this summer and I want 100% reliability, so I’m thinking I’ll have them do the PHH, and the main upper and lower hoses. Are there any other radiator/heater hoses I should have replaced at the same time? Should I do the thermostat too or are those a long lasting part?
How long do the water pumps usually last?
It’s a ’95 FZJ80, with 86,000 miles. Thanks much.
Hoses are about 12 years old. If I was heading in tom a remote area I would replace the all. I have 180k 1996 on the original water pump and it was working fine but have replaced it as maintenance.
The tough ones are the firewall and drivers side engine hoses.
The PHH is one on the side. All the others you can see except the rear heater hoses.
OK good info. I don't think I need to mess with the water pump.
But the PHH and rear heater hoses definately. Possibly all the other hoses at the same time just to get them done.
Any ideas on the thermostat? I'm currently not having any issues, but I thought a new one probably couldn't hurt, since it's a cheap part.
I replaced 18 hoses on my '97, including 4 for the rear heater.
Trying to change the heater hoses near the firewall is a bear, especially if you fubar any of the heater pipes like I did. I wish I could have waited until I could couple it with removing the TB or something, anything to make more room.
If you do it yourself carefully cut the old hoses off, don't use pliers. You'll regret it if you do.
Ross
