Which Bilstein Steering Damper??
I believe there's only a few bolt-on replacements, TJM, OME, Ironman etc. Basically all the companies that make lifts for the 80. I have a Bilstein damper, but mine is a custom steering setup
I am quite happy with my OME damper, made a huge difference over stock
Would you guys use a damper with an otherwise stock setup? I'm replacing the stock shocks on a mildly neglected 96. I'll probably go 4600 series since I don't really go much farther than dirt/gravel stuff.
The readily available aftermarket dampers (OME, TJM, Ironman, Tough Dog...) are cheaper than the OEM one.
OME to match your lift.
