My guess is you have an LS-1 engine or crank. You should be using an LS-1 flywheel with 2 1/8" center pilot hole (externally balanced). You will need Chevy bellhousing with appropriate bearing retainer alignment hole (probably 4.68?? inches). If SM465 is 10 tooth or 35 tooth output shaft, you're good to go. If output shaft is 32 tooth, it must be changed to 10T or 35T. You need 168 tooth flywheel with appropriate starter. Flywheel must be drilled with Borg & Beck bolt pattern. We sell these flywheels with both bolt patterns (original metric LS-1 pattern and older B&B). You must use our special clutch pressure plate and disc #31210-FV8, which works with the limited travel of your Toyota hydralics and fits the B&B pattern drilled into your LS-1 flywheel. You will need a #716155 pilot bearing adapter for the LS-1 crank. It fits the 1.707" hole in back of crank.
