Which 4x4 is better?
Minnesota
I've been thinking for a while now, and it's been bugging the heck out of me.
A few weeks ago, I took my 92 Landcruiser hunting on some openfields that had about about a foot of snow (2-3ft in some areas). When I got there, I met another hunter that had a 2006 Tacoma 4x4. The funny thing is....he got stuck in the snow, and I didn't. I tried to get stuck but couldn't. Was it the tires? Was it the difference in our 4x4 system? Is there a difference in our 4x4's? Or would you say the weight of our vehicles made a difference?
We had to help push him out from getting stuck.
Looks like you had BFG AT, what did he have?
If he had the BFG rugged trails it was the tires.
Of course the 80 is a superior 4x4 but I wouldn't have guessed a taco couldn't keep up in a little snow.
Oh. He had stock tires. But you would think..."4x4 stuck? Can't be?!"
So you think the 80's do have a better 4x4 system?
Tell him to go buy the same size BFG AT's that you have and go find out.
However you should already know he answer.
Your cruiser is a full time 4 wheel drive, maybe that had something to do with it too...
That taco doesn't have the locker, so it was really only 2wd (1 in front, 1 in rear) spinning on the car tires they put on them. Plus your upgrade in tires makes a bigger difference than people realize. Now if you had lockers and engaged them, it's not even fair to pick on the taco:D
92 cruiser, chances are the cruiser had no lockers unless added, and if the tacoma was a trd ext cab, it may have had the locker option, but yes in the picture it doesn't look like it; however, no locker in a cruiser means 1 front 1 rear wheel spinning in most cases as well. (w/ center diff locked), so yes I would have to say, Tires make all the difference.
I can't speak to this exact situation but I don't think that the driver's capability, or lack there of, should be discounted. In off-road condition this is just as important, or more so, than tires, lockers, etc; although, they all help. I have seen stock trucks, with awesome drivers, pull through some muck that the best outfitted 4x4 would not make it through with an unskilled driver.
The biggest difference between those two vehicles is the weight. More weight in this case means more traction.
And more importantly, where it is distributed. Trucks carry very little weight over the rear tires.
Jack
Thanks for all the replies everyone! I just wanted other opinions. But I kinda guessed that weight, tires, and fulltime 4wd had something to do with it. Does anyone know what the center diff lock does? I've never used it before. I know it still works because I can hear it engage when I press the button.
I would bet tires too.
A few years ago, a friend and I had nearly indentical set up Toyota trucks, duel lockers same tire size, about the same weight, but he had new BFG muds and I had nearly new siped MTRs. Going up a snowy trail, I could go anywhere I wanted and he was constantly getting stuck and I was constantly having to pull him out.
So, tires count for a lot, especially in snow.
That said, the LC has an advantage over most pick-ups in that there's more wieght over the rear and the weight is more evenly distributed.
