Where to start?
Bradenton, FL
While rolling against 3rd gear down hill and turning slightly to the right I get a loud roaring sound and I cant tell where its coming from. I also get this same sound occasionally while in reverse with the wheel turned to the right but not every time. I just replaced all inner and outer wheel bearings, TRE's and brakes. I'm wondering where to start looking...birfields, front diff, transmission, transfer case?? This sound happens in 2wd and 4wd works fine although I havent tried to make the noise happen in 4wd. Just looking for a punch list from anyone who may have an idea whats going on. I will be changing all fluids today to see if theres anything obvious. BTW 77 BJ40 daily driver in Costa Rica. Thnx in advance if you can help.
keep a better watch for tigers in the road, that should cure your roaring problem!!!:princess:
Will see if I can make it do it with someone next to the car. BTW all fluids were changed and everything checked out perfect except the front diff (water). No chunks of anything in either diff, transfer or transmission.
The rears were changed about 3 months ago. I am almost positive the sound is coming from either the transmission or the front diff, but I'll see if the person outside the thing hears something different.
I had the same type of problem once. Turned out to be coming from my 3-speed transmission. To find out for sure I went to a local mechanic shop. He put my FJ40 running on a lift with me inside. Running through the gears while he was underneath it was easy to isolate the noise. This way I did not start replacing un-needed items.
Hope that helps!
Freakin U-joint (forward rear shaft). I have checked it 3 times in the past 2 days and found no slop. This afternoon I spent some time rotating it and found 1/8" of slop in only one direction in one specific position. I hope this is the source. Thnx for the input.
