where to start?
Eagle River AK
(74 fj40 with a 70's cevy 350, converted to electric fuel pump)i was making my first freeway road test after tweeking a few things for drivability purposes after a spring over. I made it about two miles down the freeway then the radio turned off. came on for a spit second then the whole truck died. pulled over and popped the hood and i found that the positive battery cable had been touching the exhaust manifold and melted through the cable and grounded out. I figured i fried my battery. got it home threw the battery on the charger set it for a quick charge at 12A only to come out a few hour latter to find that the charger light flashing to indicate a fault. (but when i turned the key i could here the fuel pump come on) I checked the water in the battery turned the charger down to a 3A slow charge and left it over night. come next morning charger has a green light and says its 100% but now when i turn the key i get nothing. Battery reads 12.59 volts, 0.00 ohms from battery cable at the post to battery cable at the starter. there is a large 50A fuse where the main power line goes into the cab and i am reading voltage (12.38) at that both posts. only fuse that is blown was the wiper fuse. But i am only getting 5.59 volts at the brake light fuse. Where would you start? (it is a new wiring harness been installed for about 70 miles with no issues)
Voltage reg? melted wires under the dash? battery dead?
Bring it to a shop/parts store that can load test the battery. Napa, AutoZone, O'riley's, CarQuest
This.
Another option is to have someone turn the key while you watch the voltmeter. I’d bet it goes straight to 0.
Voltage at the battery is only part of it. if your battery overheated it could have dropped a cell and the others are overcharging. This could cause the fault you saw from your charger.
yep they tested it, and the top posts no longer worked. switched to the side posts and all is well, once i make it into civilization i will go to the interstate store and see if they will warranty it since its only like a year old.
