Hi everyone, I have an original DENSO 12V winch. I like to replace the oil, but I can't find the drain. I can see the fill area on the passenger side. Any chance someone can give me a tip on where it might be? Thank you.
Thank you Aztoyman. Means have to remove the winch to change oilHere's a manual from a mud post in 2016. Looks like you drain and fill from the same port. Obviously with the winch on the bench. Says automatic trans fluid. Dropbox - https://www.dropbox.com/s/bevy5mdjgkwe65t/fj_hdj_hzj-80_series_winch.pdf?dl=0
Thank you, it will save time from removing the bumper too. Maybe it won't remove all the fluid but enough to replace it. Thank you for the tip.Use one of those suction/vacuum units for changing engine oil in a boat. Like this:
