Where can I get springs for a M100?
Thinking or buying a M100. PO took out the springs, and bolted the axle to the frame, to lower it, to pull it with his side-by-side ATV
Not doing a trailer restoration. Just want it functional for vehicle use. Anything special about the mil spec springs, shackles, & hangers? Can I call up my local trailer supply store, give 'em the measurements, and get a pair that will fit ?
Thanks once again the forum rocks !!
One more detail. Do these PN's work with the original shackles or do new shackles need to be purchased ?
original "C" type should work. Newer double sided will work too and much cheaper. check the spring length on m100 v m416 before you buy. My understanding was they used the same springs as the front on early jeeps for ease of swapping parts.
from: leaf spring assy NOS (springs for m416) "These are NOS government assemblies. They can be used on the earlier trailers too".
