when to use locking differentials
I have a 96 LC with factory front and rear locking differentials. I was wondering under what driving condtions is it safe to lock the front and rear diferentials. When rock climbing is it okay to lock both diffs all the time especially if there are few turns to negotiate? Or do you lock them only when you're stuck. I'm not worried about the handling of the car, but more of the mechanical integrity of the differentials. I think my owner's manual says only to lock on materials that slip like dirt or snow. Any thoughts appreciated. -mitch12-
Normally you would engage them only when needed-i.e; you're stuck or experienced enough to know you're gonna get stuck without them. If you're unsure, engage the rear locker, and use the front as a last resort.
I run some fairly knarly trails, and rarely have to engage the (axle) lockers. There are times when having the axles locked will give the truck a tendancy to slide sideways rather than track straight, which can be very dangerous in an off-camber situation on a shelf road or next to a dropoff. You will hear this alot- get used to driving your rig with open diffs, it will make you a better driver.
-Spike
And never in the snow unless you are already in the ditch....
There's no surer way to get there if you aren't.
And welcome to the board:flipoff2:
I
But like most "rules" there are exceptions, if there is a large accumulation with no or little pre-existing tracks I find that locking it up is the only way to fly(at low speed). All of the diff lock options from just the central, rear, front, or rear and front increases the traction but decreases the handling characteristics dramatically. The central diff lock engaged puts 50% of the "drive" up front (as opposed to 40%), this is the "mildest " form of lock, and when either front or rear or front and rear are selected the wheels on the axle(s) turn together, great for traction but absolutely brutal for handling. As was said earlier locking the front should be seen as last resort because unless you're on an absolutely straight road it's a handful. Hope this helps, Tony
