Just spent several hours reading through a bunch of "grey sludge" posts. I don't know if anyone ever figured out what the stuff really is, but if they have, can anyone enlighten me? I've read all the theories, but I wasn't sure if anyone actually had it tested. My system has had both green and red and I recently flushed and went back to red after the PO had green in there.
Anyway, the top of my radiator looks like its full of the grey sludge. Really thick to the left of the fill cap. I don't have overheating problems, but I'm in the middle of a major cooling PM and have the radiator out right now. I had a local, sort of fly by night, radiator shop flush it for me, but it looks the same inside. At least they did a good job on the outside.
From what little I can see, it looks pretty bad, even like some tubes are pretty well clogged up, but the radiator still cools the engine. I'm not sure how, with the way it looks to me.
At what point would you guys just replace this radiator with a new one. I figured on going with a 3 core '94 from C-dan if/when I ever needed too, but wasn't sure if this justifies the replacement or not. The only other option I can see is maybe having a competent shop rod it out maybe.
BTW, '95 FZJ80 w/ about 96K miles, original radiator, original headgasket. I'm currently replacing all the hoses, water pump, thermostat, heater hoses, clutch fan, etc.
