When to perform first oil change?
Texas, USA
Manual says 10K, unless I'm driving in extreme conditions - in which case it recommends 5K.
Seems kinda late for the very first one. I recall my new BMWs needing a change after the first 600 miles, when running on full synthetic (granted, these were M division cars). I'm normally one to follow factory guidance - especially as frequent oil changes are a waste of time/money with synthetic oil - but with a brand new engine should the first change come before 10K?
In the modern era of synthetic lubricants and machining everything I've read and heard says we don't have to change the oil on a new engine like we used to. I believe it to an extent.
That said, when I purchased mine I did the first oil change just shy of 1,500 miles. The second at 5k and third at 10k. I've used AMSOIL Signature Series 0W-20 (which is reportedly good for 25k between changes) and used either the TRD or AMSOIL oil filter (the latter of which is reportedly good for 15k intervals). I fully acknowledge that it's overkill for the over-engineered Land Cruiser, but it it can't hurt and could potentially add to its longevity.
Edit: I will add that on the first oil change I added a fumoto valve which makes the draining process on the LC easier and a little less messy. I also swapped out the stock plastic oil filter cap for a Toyota aluminum replacement.
Others have noted that the first diff change should come earlier than the manual states, but should be good thereafter to adhere to the recommended intervals.
Some engines come from the factory with a "factory fill" oil that is different than the oil that is recommended after that first change. It is my understanding that the factory fill oil is usually not a synthetic and this is to allow some wear and for the engine to actually "break-in". The manual may be going by the same logic in that, by 10k miles, the oil has broken down enough to actually allow some wear on the internals, in a good way. I'd do what the book says at first and then, if you are really anal, use oil analysis to determine your optimal oil change interval thereafter.
