When to align
Yuma, Az
Question on when to align. I'm going to be installing a 2.5 ome with the caster correction bushings that come with it. Since I will be ordering a slee rear bumper then an arb front later, would I have to get the alignment before or after bumpers? The rear springs are mediums btw. Also Im thinking that before I press in the new bushings, I would want the weight on it, or is my thinking all wrong?
Alignment is really for adjusting the toe in and tell you the caster number, they can't do anything about it so justo the alignment adapt after the bushing.
I would not do an alignment yet. I also would not install the CC bushings yet. Install everything else. Get a caster reading, correct as needed then as said get an alignemnt..... but knowing there is very little to align on a 80.
or go buy a Firestone lifetime alignment and go as often as you'd like.
I usually go before a long trip and after wheeling
