when replacing front brake hose, do I...
wussyPup
just another ex-VI Cruiser
Langford, British Columbia, Canada
Website
www.flickr.com
I have a bad flexible brake hose leading to the left front caliper; it is bulged near the caliper end fitting and leaking fluid.
When I replace it, should I also replace the union bolt and gaskets?
Besides replacing all of the other flexible hoses, is there any thing else I should do while I'm at it? (1990 HDJ81 with 4 wheel disk brakes)
Thanks, -Steve
Parts of interest in the pic below:
Code:
47313J 90947-02612 9001-9208 HOSE, FLEXIBLE, NO.2 (FOR FRONT LEFT)
47313B 90401-10015 9001-9801 BOLT, UNION (FOR FRONT FLEXIBLE HOSE)
47313P 90430-10074 9001-9801 GASKET (FOR FRONT FLEXIBLE HOSE)
Bolt no, not unless it is damaged/rotten but the copper gaskets yes, in a bind you can reuse them but if you have time to order parts before hand you should get new ones. should not be expensive.
