When it rains...
Fayetteville, AR
Any thoughts on where my 1997 FZJ80 leaks?
When it rains hard, the rear passenger seat belt (2nd row seats) gets saturated, when it is retracted into the side panel. The Toyota dealer has no clue, and says finding the leak will likely take many hours and much $$. Any advice will be appreciated.
Your dealer is a moron. Sorry, just had to say that.
The sunroof has four drains - one at each corner. You can see all four of them with the sunroof open and they're rubber tubes that go down inside the body to the rocker panel. One or more of them is blocked up at the sunroof and water is over flowing the shallow drain pain that guides water to the drains so it runs back along the inner roof to your B pillar.
Physically look at and check them. A gentle (keyword) blast of air will help clear them. Then check to see the slit drains in the rocker panels are not blocked with years of dust. For grins, pull the round plugs on the rockers somewhere near the forward edge of the front doors. Stand back.
DougM
Post #22 of this thread has pics of the slit drains and round plugs that IdahoDoug mentions. Zip tie works great for cleaning out the slit drains..
Slit drains
Bingo! If I was the head of a nail, I'd stay away from Doug! He hit it!
Mine was rolled when I bought it and this is the only problem. Somewhere the drain for the RR of the sunroof is pinched and the RR seat belt is always wet after a rain. The sunroof cannot be sealed from the top. It is designed to leak into a drain trough that leads to tubes that go down thru the body. You can find the lower end of the tube and blast it out with an air hose to remove debris. That is if yours hasn't been rolled... I have a bit of a bigger problem, but I will get to it one day. Hopefully before the in-laws visit again....
Oh, and another note. Until you resolve the leak avoid the automatic car washes that use high pressure water jets. I found this out the hard way - Looked like Niagra Falls :frown:
Now I just avoid these type of car washes all together as I'm not convinced perfectly clear drains on an 80 can get rid of that much water in that short amount of time.
When it Rains - Part 2
Well guys, I cannot locate any back corner drains - used a high beam flashlight & can't even see the back corner (w/sunroof open). The drain pan goes too far back into the roof interior. Is it possible to access them without removing the sunroof?
I easily located the front two corner drains with the sunroof open, blew some air into them, tested with small amount of water, and they drain fine out bottom slits. I pulled the rocker plugs & all was bone dry.
While pouring water slowly into the drain pan, I noticed the pan seems to be tilted to the front, perhaps designed to direct water to the front two drains?
Thanks for the continued advice.
Well guys, I cannot locate any back corner drains - used a high beam flashlight & can't even see the back corner (w/sunroof open)...
try clearing them from the other end? The rear ones exit in the rear quarter panels, under the truck. In this pic it's the bigger hose, the other one is a diff breather that I added.
x2 on this.
Like you, I couldn't "see" the rear sunroof drains (I didn't try a flashlight though). I found a spool of some bailing wire type stuff lying around the house that was like 20' long. I used that to stick down into the sunroof drains. I poured a LOT of water down into the drains (had to park the rigs uphill to get water to go into the rear drains) and it rushed out nice and fast. However, I still found that you can overwhelm the drains capacity to get rid of the water...Especially in those high pressure automatic car washes.
As for the rear drains Tools mentions...You can also see them is you remove the access panel where your jack is (back and left as you look in) or if you remove your right panel trim.
The DS rear drain tube is the easiest to see from underneath as there isn't the resonator/tailpipe blocking the view.
On another note, my slit drains on both rigs seem perfectly clear and dry like yours as well. I still went ahead and did the zip tie procedure figuring it couldn't hurt.
Thanks guys! I found the exit hoses in rear quarter panel & shot some air up in them. Probably need to procure some bailing wire & try that approach as well (a next weekend project). I also did the zip tie procedure as advised. Have a great week!
Ted
Ted
I would get a spool of heavy weed wacker line first. Wire may puncture holes in the rubber tubing when trying to go around curves.
Good point :)
I used what I had lying around and it had a little plastic doohickey stuck on the end so it seemed safe to use...On the last drain I used it on though that plastic doohickey didn't come back with the wire though :whoops:
Stiff weed wacker line sounds like a better alternative...
Has anyone gone from the output end up as opposed to the input end down before? I wonder where the drain tends to clog up and if it is toward the output end or input end? No sense in trying to push a bunch of crap all the way down if it is sitting close to the top.
For the rear drains I used a electrical wire fish (the type you use for wiring your house) and ran it up from the bottom (it already has a loop on the end do it won't damage the tube). Then I duct taped a couple feet of heater hose (about 1" dia) inside the end of my shop vac hose and ran that back to the rear drain from the top side. When it got back there I heard a clump of something go through the vac. I then ran water through the drain. It should flow pretty fast. Anyways, that's what worked for me.
