Wheel Studs
Brentbba
Former Golfer
OC, CA
How easy/difficult is it to change a wheel stud. I sheared one off of our scout troop trailer Sunday afternoon dropping off some gear at the Scoutmaster's house. Storm drain outside his house has a protruding edge on it and I found it!Fortunately we have a dual axle trailer and the wheels are a six lug pattern. I caught the front left wheel, puncturing the sidewall and denting the hell out of the rim. Both are obviously toast.
The one lug nug was difficult to take off and that should have been an indication of trouble to come. Other 5 were fine. Slapped the spare on and started tighening the lug nuts. I did use an air gun to make the job easier both off and back on. It wouldn't budge the bad stud. Took my breaker bar to it and got the nut to turn a little. Second pass and snap - off came the stud. :censor: :censor: :censor: Very unscoutlike verbage spewed forth from my mouth. :whoops:
Anyway - can any shop with the correct size stud do this fairly easily? I have no clue here. I've got a little time as we have no trips planned with the trailer again until October, but I want to get it taken care of.
What type of axle? Does it have brakes? Can you just hammer it out the back and pound a new one in?
I'd have to look to see if this is the axle with the brakes on it or not.
Given the shape of the hub from memory, I'd say this one is the original axle, thus having brakes.
I was tired and pissed off after a long weekend and I didn't pay any attention to it. I already had the other five lug nuts tightned down and I wasn't about to take them back off to see what needed doing. All I wanted was to get the trailer down off the floor jack and take it back to the church!
I know this wont help fix the broken stud, but I would put just a small dab of anti-sieze on each stud next time. Trailers are notorious for lug nut/ wheel stud problems.
You should be able to hammer out the broken piece and pound in a new one; problem is getting to the back of the flange. You may have to remove a fair amount of stuff if it is the brake axle.
Since you're just a :banana: guy you might want to drop it off at the closest trailer shop and be done with it. There's a pretty good trailer shop by my house. If you want the address, let me know.:flipoff2:
I'll probably just take it to the place that put the 2nd axle on last year. Maybe the same shop? Orange Coast Trailer Supply on Ford Road just before Triangle Square at 19th and the 55? Great guy. He's been there working on trailers since the 60's!
