IH8STUDS!!!!!!!!!
the reoccuring theme of broken studs has now passed from the taco to the 80.........
so as it says im due to replace a broken wheel stud. i tried searching and only found some older threads on the need for longer studs but they didnt get to the the installation part of the project.
i was looking through Clowns rear axle service thread in FAQ and a few others. https://forum.ih8mud.com/showthread.php?t=80429
is it correct to say that i would need to remove the rotor (of course) and then go on to remove the hub body, or can you remove the stud while the hub body is still on the vehicle. (SST?) all the studs ive dealt w/ so far have been a torx socket, but these are threaded to the end and look to be sealed from behind. if im goin that deep then i'll consider axle seals but i'd rather not if i dont have too.
i am using anti seize and hand tools ( no impact guns ) and usually real good at going behind the shop to retorque to spec.
heres how it happened if it helps... the joys of two sets of wheels and tires. i was swapping the mt's on for a trip to the woods and the lug began to back off fine, as i continued to back it off it got progressively tighter about half way out ( wheel was off the ground not bearing weight) and as i was thinking to go back on a bit it broke w/ suprising ease.
any and all info is much appreciated and of course feel free to point me to any threads i may have missed w/ the search button.
