wheel spacers
Most all of the CNC machined alloy spacers that I have see are virtually the same, having Dorman wheel studs, etc. Ether made in the same place or heavily copied. The exception is some high$$ custom units that are made for specific wheels, applications.
Why do you need them? I'm not a huge fan of them, unless there is a need. Having double the contact surfaces and fasteners is not good for reliability, twice the chance of failure. Use with care, property torque them, then be sure to recheck the torque after a couple of hundred miles.
That said, I run them on my currant setup, the rims have more backspace and with the big tires, needed more room between tire and frame. With bigger tires and stock rims they can push the tires out enough to cause rub issues at the outer fender well, requiring more bump stop spacer to solve.
