Wheel size
Leander, TX
Im looking to get new wheels for my 1992 FJ80 currently I have oem 15x7 wheels Im looking for some 17" wheels and wanted to make sure I get the correct ones.
Do i need to find wheels that are 106.1mm or 108mm Ive read conflicting info on other posts just want to clear that up.
Thanks in advance.
Bolt pattern: 6 × 139.7 mm
Center bore (hub bore): ~ 106.1 mm
FWIW, your OEM wheels are probably 16”, not 15”.
I'm pretty sure the 91-92 FJ80 did come with 15" rims. But of course the larger diameter will fit just fine. You'll want 0 offset for a stock stance, or you could go with -6 or -12 (negative) offset to push the tire out for a wider stance and to better clear larger tires.
Nope my wheels are definitely 15” Im running 35x12.5r15 I wouldnt mind keeping the oem wheels but Im having a hard time finding someone that will mount 12.5” wide on a 7” rim… plus the new tires I want they dont make a 35” for a 15” rim.
Thanks for the info sure do appreciate it
I'm pretty sure the 91-92 FJ80 die come with 15" rims. But of course the larger diameter will fit just fine. You'll want 0 offset for a stock stance, or you could go with -6 or -12 (negative) offset to push the tire out for a wider stance and to better clear larger tires.
Yes mine came with 15” rims…
Got it was planning to stick with 0 offset just wasnt sure what bore size I needed… There doesnt seem to be very many 106.1mm rims out there.
For my 1991 FJ80 I bought EvoCorse DakarSuperZero 17x8.5 ET -15 (Anthracite). Their quality and finish are stunning!
Icon makes a couple of wheels, with different finishes, for our rigs that have the correct backspace. I got the recon pros. Bonus, Delta makes caps that will fit over the front hubs for these wheels.
Anyone running Dirtylife wheels there website says hub size is 106 and wondering if that will work or not? Anyone have any experience? Thanks
