wheel lugs
Hi All:
This is not what you asked for, but perhaps might contain some info that may help in your search for one inch longer wheel studs.
Good luck!
Alan
To: <landcruisers@tlca.org>
Date: Thu, 24 Oct 2002 14:59:09 -0700
Subject: [LCML] Longer Wheel Studs for RDB conversion
Ever since I did the Chevy rear disc conversion, I've been a bit
uncomfortable with the shorter usable length of the wheel studs due to the
thickness of the rotor's "hat". I finally got around to replacing the studs
with longer ones. I used Napa p/n 641-1628 (Balkamp), about a 1/4" longer
than the original ones. They're M12-1.5x44.5mm, $1.99 each. The Specter
says that FJ40 models from 1968 to 7/80 use the same stud so I assume that
these would work on all those years, too (mine's a 71).
Don Kinzer
Portland, OR
you can also get DORMAN part #610-265 10 to a box they are M12-1.5x44.8MM
i dont know if you can get them an inch longer but if you can find a place that sells dorman products just have them look them up.
