Wheel bearings preload adjust (just 1 nut)
Holstebro, Denmark
So I am working on my friends 2001 hzj79.
After re-greasing the Wheel bearings we need to tighten the nut. But I am having a hard time finding the right procedure.
My own 75 series has the 2 nuts with the lock washer.
This 79 series has just 1 nut and then the strange cup for the auto hub seems to lock it in place.
I am guessing it is the same procedure making sure the bearing is seated. Tighten at 56Nm, loosen , repeat...
But with how many Nm should I tighten the last time and then align the grooves.?
Does that make sense?
I am using the online manual but just can not find the precise page
Thanks. That is perfect. So finish with 49Nm plus whatever it takes to align the next groove and the right resistance turning the hub.
Even though I am not a 100% sure I understand how I install the weird little cup correctly.
Have anyone ever found a video online of someone doing this. Have only seen videos with the traditional luck/unlock hub. Not this Auto hub we have.
