Wheel Bearing Question
Arkansas
The other day I was working on getting the rest of my baselining (brakes and wheel bearing pack) done on my 97, which I've only had for a few months, when I ran into a slight problem. I started on the DS and took everything apart and the wheel bearings appeared to have been freshly packed. Everything looked perfect, I repacked the bearings and put on new brake pads. Got to the PS and everything looked as good as the DS. I repacked bearings and was putting everything back on but couldn't get the torgue on the nut and the preload with the spring gauge to work out right. After several failed attempts to get it to work out, I finally decided to tighten the nut until the spring gauge worked out right (6.4 - 12.6 lbs). I had to tighten the nut tighter than the FSM says but the spring gauge is reading around 11 lbs.
I didn't have this problem on the DS and was wondering if anyone had any thoughts on this. Is this something that is normal or do I need to go back and do something different?
Thanks for the help!
Does anyone have any advice on this???
Search Landtank's method for preload. He doesn't use the fish scale. After doing the initial torque to 47 ft/lbs, he backs off and then torques to 10 ft/lbs, turns the rotor a few times back and forth and keeps torquing to 10 and turning until he maintains 10 ft/lbs. Do a search for his posts though to get a very thorough description. I didn't find his posts until after I finished my front axle service. I couldn't get my fish scale reading below 15 ft/lbs on both sides, but so far it has worked out okay( less than 1000 miles since I did the front axle). Anyway, good luck.
Jeff
