So I just rebuilt my front axle a week ago and checked the wheel bearings for play yesterday and yeah there was some....sh*t... For what its worth i had a hard time getting the passenger side to fall into the breakaway force requirements so i backed one of the nuts off to get to 12.6 lbs...so now should i just take the wheel off and re-torque the two nuts to the correct spec even though the breakaway force will be high?
ps just checked my torque wrench and it is within 1 ft-lbs
thanks in advance and hope to do this today if the temperature gets above 32*
barrypt5
barrypt5
) and did the LandTank method, I did not remove my brake caliper so getting the breakaway test in spec was pretty much out of the question...but for sure no play now. Went for a drive and made alot of turns then rechecked...no play so I guess good for a while??? I need to keep an extra drive flange paper gasket though, one side tore slightly...dammnit
