Whats this noise?
South Africa
Hi fellow Cruisers, I have a weird noise which sounds deep opposed to high pitched not quite a whine, hard to explain but very noticable,, it happens when switching on the climate control at highway speed,, the car has a 1HDFT with EGR, any ideas
Tks
Al :frown:
Engine or behind the dash? You might get better response in the 80 section. If you don't many responses in this section I can move you over to there.
Is it the ac compressor starting to turn?
Is it only when you use the climate control or does it do it anytime the ac is turned on?
Its happens, when hitting auto on the climate controll, when I switch off it goes away, cant remember if I tried leaving CC on and turning AC off I'l give this a try just to make sure
tks
