What's this hose?
Ski Town USA, CO
What's this hose called that I've highlighted in the pic below? It's cracked where it attaches to the valve cover. I don't know how critical it is but I'm a big fan of PM.
You think this is something I can pick up at my local parts shop or is it a preformed Toyota OEM only hose?
Thanks bunch for the assistance.
You could probably replace it with some kind of generic hose, but getting it from Toyota looks better. It is called "ventilation hose #2", and if this is for your 97 in your signature, then it is part number 12262-66021 and costs about $12. Call CDan to order it. You might also take a close look at the hose just to the right of it in the pic that also comes out of the valve cover as that often cracks too. About $9 for that one.
while you are at it, check your vacuum hoses in between the vent hose and the PCV hose. Mine was cracked and upon further inspection of the other vacuum hoses several were on the way out. I bought a few feet of 1/4" inside diameter vacuum/fuel hose IIRC (the larger of the two vacuum hoses) and went to town replacing stuff. Good luck.
Thanks I'll do that. It would make sense that the other hoses are just waiting to give up the fight.
