What's my front axle worth?
Eskimo
Danville, PA
Website
www.rnrfab.com
Sorry for the x-post, it wasn't getting much traffic in the 40 section..
I'm planning to swap out my front axle with something else this winter, and I'm trying to gauge the market... So here's what I've got, lemme know what you think..
Trail only rig
FJ40 housing.
cut & turned for 12° pinion, 5° caster
housing modded to have a removable diff cover, which is armored. (GREAT mod!)
4.10 third, lock-right, round pinion flange (coarse spline though)
mini truck knuckles
Rock buggy supply high steer, uses 1-ton TRE's.
vented brakes
spindle stud kit
good calipers/rotors/bearings/seals
aisin hubs
4340 birfs (27 spline)
4340 inners (PolyPerformance)
would include u-bolts & spring plates
Spare parts:
1 aisin & 2 warn lockout hubs
1 spare cromo birf
spare (stock) inner shafts
spare 4.10 open third member
So what would you all say the going rate is?
Thanks...
Stock front axles are worth$250 when someone needs them, when you want to sell them$100 is a good price to get rid of them......Yours are drum brakes if you had disc brakes $450-$600 for the same axle I have sold probably 10 axles and sometimes I give the old ones, away 73 and older. I have a set off a 1973 that I will gladly sell both of them for $75 each dave at Rockntag@msn.com
No offense, but did you actually read what I wrote?
"Good calipers/rotors" "vented brakes" (Meaning, FJ60 discs)
dont think he did but if your interested he will sell you a set off of a 73 :flipoff2:
I just parted a similar fron fj60 housing... heres the pricers I got for almost new components:
cut & turned housing $140
Treated longfields: $150
3rd w/ 4.88's $150
lockright $150
Brand new high steer w/ TR & DL $215
Can't sell stock inners for $25 ea.
Can't sell fully rebuilt knuckles w/ 4runner calipers & new wheel bearings for $225
This should give you an idea of what your stuff is worth. HTH
