the other day i was under my 80 and found a leak in the rear part of my transfer case. it seems to be coming from a sensor or something like that. it is leaking fluid from inside the trasfer case and is leaking the case pretty wet. any ideas? the part is electrical and is round where it attaches to the case. ill see if i can get some picks. thanks
Ditto; vehicle speed sensor; First disconnect the electronic connector by squeezing it, then unbolt the bolt that holds the assembly in place. Then the speedo shaft pulls out. There are two seals; one little spring wrapped thingy (Speedometer driven gear oil seal) like a mini-axle seal, you'll need a curved dental pick-type tool to pull out, and then an O-ring. They often leak a tiny bit maybe more with synthetic gear oil. My last one lasted about 75K before it started seeping. Looks like a lot of leakage, but IME it is not; almost like one drip just kinda hangs there a long time. I worried and worried over that; too busy to get it done, "oh my gosh, I'm gonna run my transfer dry--". Nada; pulled the fill plug and gear oil came dribbling out. Of course, fix it as soon as you can (after you get the parts) and if you can't, at least check your gear fluid level in the transfer.
Another small point; almost no one (mechanics that is) replace the washers for the fill and drain plugs. It would be hard to get them to leak, but next time you do change your gear oil, then would be a good time to replace the washers (and plugs) with new. The solid aluminum type washers get kinda welded on the plugs, so be prepared to cut them off; or, just buy new plugs ahead of time with new washers.
ok thats a relief! ive been worrying about it. it is on the driver side and it does have one bolt holding it there from what i can see. im going to get it fixed tomorrow. thanks for the replies!
