What's in YOUR diffs?
Austin, TX
I can't seem to find a straight 90 weight gear oil to change differential fluid. Is there a multi-visc. fluid that you guys like (those of you in the south that skip over references to <0 degrees F). I was looking for Mobil 1, but no luck. Also, does the bottle have to say "hypoid"?
Also... when I was trying to track down a grrrr noise, I changed the front diff fluid to M1 75w-90 syn gear lube (about 2K ago). Close enough? That's the correct wt. for the t-case, right.?
You are good to go with M1 75W-90 in the diffs and t-case.
75w-90 and 80w-90 are fine to run in the diffs and T-Case. Just make sure they are GL-5 rated.
gear oil :D
Thats too personal a question!
Sean
Mobil1 75W-90 in the diffs and t-case.
Mobil 1 75W-90 in diffs and tcase as well
tucker74 said:
I've used Redline's MT-90 in my transfer case for the last couple of years - it's a 75W90 GL-4 gear oil and I would recommend it. It's made for manual gear boxes - but came highly reccomended on this board by the oil gurus -
:cheers:
Tucker
BTW - I use Amsoil synthetic gear lube (80W-90) in the diffs ...
I knew I'd answered this before ... you can pick both of these up locally at Van's in Austin -
Tucker
