What would have prevented this?
failed brakes and failed shift cable? at the same time? dunno, seems pretty unlikely to have both fail like that, but annual brake fluid change and maybe PM exchange your master cyl and calipers? at a minimum bleed the fluid and top off annually.
DOT3 sucks moisture out of the air, condenses into the master cyl res, and it 'sinks' to the calipers; long brake use boils the water and the resulting steam compresses = no brakes. :eek: pucker factor 10.
if cool headed and there is enough time, pumping the brake pedal may help.
HTH
That being said, I am highly suspect of the shift cable being broken AT ALL and especially right along with there being no brakes.
x2
Would be an odd set of circumstances for both of those to fail at the same time.
And wouldn't you still have the e-brake? May not be enough to stop it a 55 mph but you'd think it would slow you down substantially. No?
I find this article suspect as well
Yea, that's my guess - rode the brakes hard while not using engine braking enough and overheated the brakes. As soon as the fluid vaporizes, you're just compressing the vapor, not moving the pads. As for the ebrake - alot of people have crappy ebrakes to begin with, and even well adjusted I doubt they'd do much once things got going.
Not sure what's up with the shifter. Is it possible he was in high range, in which case even 1st might be to high to make a difference. Could explain the overheated brakes as well.
Did it say it was an 80?
Ah, that sounds like a load of horsepucky. It sounds like her husband possibly overheated the brakes from not having the truck properly in low range and then simply did not know what to do about it when they faded altogether. 6 people in a Cruiser, it would have to be an 80 (60s have seatbelts for 5). And at the same time something in the shifter broke and what - shifted the truck into D or N?
I think it was inexperience and human error and the kind wife is essentially covering for her husband. I'm sure they all feel bad all around, and it's human nature when you've nearly killed people you love (and someone else's kids, too) to have a difficult time admitting you screwed up. Mechanical failure is a convenient scapegoat. Nothing new.
DougM
