what went wrong...
los angeles
I just installed my new Slee light harness into my rig and I don’t know what went wrong.
When I have the headlights on if I turn on a blinker, both blinkers, ps & ds blink, and the headlights flash, with the passenger side not being as bright.
If the truck is running and I turn on the hazard switch, the truck dies; shuts off…
Do I have something crossed, not grounded? I followed the supplied directions to a T!
Have a fishing trip planned and don’t want to get stuck.
Any and all help is needed.
BTW: I did a search and found nothing pertaining to this.
RoxLC
that is the wierdest thing. The only thing you should of tapped into is one wire in the wiring harness. I would doubt grounding is the problem. It makes me think you somehow skinned some wires in the harness where you tapped and things are going haywire.
Did you touch any of the wires that go to the parking lights or turn signals?
From what i recall it's only the plugs on the back of the headlights and direct to the battery and ground. I think you got the wrong wires in there somehow.
I don't think i tapped into more than one wire. per the directions, I plugged the oem harness into the slee harness on the ds side (truck is a 94).
by 'skinned' do you mean pinched??
hmmm... so you think i plugged the harness into the blinkers and not the headlights? i will look and see. I'm pretty sure it's in the headlight.
the one part that i was a bit confused about, during install, was the part where you put the two black wires to the battery. should i have put them directely on the battery post or screw them where the oem harness was. Should I have unplugged(un-screwed) the oem harness from the batt...?
The Slee harness only plugs in one way so its pretty doubtful that you switched lights. I do though get the feeling that the OEM harness is still in the circuit somehow but I cant imagine how. The two black wires you are talking about are the fuseable links and yes they should go direct to the POS side of the battery. Did you select a good ground? Not every spare bolt makes for a good ground.
to simplify the instruction- 2 plugs go to PS, one plugs into the highbeam bulb,the other the lowbeam bulb. The connectors that used to plug into the bulbs are taped up and abandoned. On the DS, 2 plugs go to the bulbs, like the PS, one for high, one for low. That leaves you with 2 connectors on the Slee harness left. These 2 connectors each plug into the factory harness(the connectors that used to be going to the high and low beams. Then the ground wires are attached to inside fender well. The only thing left is to attach the black wires coming out of the fusible link to the positive side of the battery-directly. There are 2 left over clear connectors, these are for auxillary lights, so these are left alone. That should be it. When I mentioned tapping wires, in my case I tapped into the blue wire for my aux. lights, so that they will come on when I flick my high beams on. Anything that was previously attached to the positive terminal leave it there. Let me know if you got any more questions, and whether this fixes it.
ROXLC- once you get this ironed out, dont forget to get some John Deere HIR bulbs. Awesome.
Quick question, did you try to interpret Slee's instructions or did you follow this:
https://forum.ih8mud.com/80-series-tech/218349-installing-slees-new-style-headlight-harness.html
i used yours. they came with the slee harness
I don't have the fusible link directly on the battery post, i will change that. I think I used the same ground the oem harness was plugged into. I will double check. Thanks for the input and great directions.
I did just as the directions stated. I'll let you know how it turns out.
I mos def want to get some JD HIR's. My father in law is always at his local jd tractor and implement shop, I'm going to ask him to pick me up a pair.
most likely they wont be in stock, have to order them but they are worth it.
ROX, where abouts are you? If you don't get it going I could swing by if you are local enough. I'm in Woodland Hills.
i'm in los angeles... abt 20 mins south of you, if the 405 is moving... crescent heights\pico area. i can come your way.
let me know...
problem solved...
after a conversation with NLXTACY(thanks again) I figured out the oem harness needs to stay grounded :doh:!
Once my JD HIR's arrive, life will be great.
ROXLC
