As you are desmogging, you can eliminate the EGR system completely, since it is part of the emissions controls. In simple terms, the j pipe from the exhaust manifold, the exhaust cooler on the DS side of the block, the vacuum valve bolted to the side of the intake, and the pipe to the PCV inlet (the one in my pic above). Plus the pipes and servos on the fender, and the hose/pipe that goes down to the exhaust below the floor.
For the J pipe, you can make a block off plate or just remove the pipe, cut and seal it, and put it back. The heat shield hides it. For the pipe that goes under the floor, as Jim says, the proper way is to cut it off at the exhaust and weld it up. The hillbilly way is to cut the hose below the brake booster and cap it with a rubber bung or a big bolt. Someday I'll do it proper...
