what tyre pressure?
UK/EASTERN AFRICA
Just bought some pretty cool Kumho KL71's 33x12.50xr15 :)
What pressure should I be running them at, on & off road? :confused:
Thanks in advance!
None, leave them flat, they get better traction that way.
Read the tire FAQ, I wrote a treaties on how to adjust tire pressures based on going from a P-Metric (OEM tire) to a LT Tire.
If that is to much work, 42psi for the street assuming a stock weight truck, add 3-5psi if your truck is loaded with bumpers, sliders, winches, drawers, etc.
best is to contact Kumho and ask them, providing info on your truck's weight.
For off road: however low you need for good traction and to minimize tread damage, vs how much time you'd like to spend reinflating them.
In real life: On asphalt I usually see 40-60 psi for LT tires. Off road: smooth dirt: 25-35, rough dirt: 20-30, rocks 15-25, sand 12-20, but that really should depend on the tire, your preferences, the terrain etc.
sorry, you'll have to convert the psis to Pa or whatever you're using there...
