What type of Steel Tube for Tail Shaft?
Glen Waverley, Victoria, Australia
Website
jonathan-ferguson.au
With the two piece rear Prop Shaft on a Mini Pickup, the rear section has Universal Joints at both ends(unlike the front section), I want to cut the Tube out Completely and Weld in a new piece of Tube. :cheers: Any problems with this idea?
not a problem at all.
You want to make a 2 piece DS into a 1 piece DS right?
Yes
What type of Metel am I looking for? - DOM of some description?
.090 tubing that has the ID you need. Off hand I can't remember what exact OD tubing you want..
But there is no reason you can not turn the DS ends down to accept a certain ID tubing..
Can I Weld to the original Welds, as I don't think there'll be enough materiel left if I cut closer to the Uni Joint on one end and the Slip yoke on the other?
Whilst the Tube is being cut to length on a Lathe, should I put a Chamfer on the ends of the Tube, for Welding?
You might even fish mouth the end of the tube to increase the weld length.
Today, I couldn't get DOM. :doh:
Firstly I went to a place in Springvale, it had moved(Yellow Pages are only a few weeks old), I found it around the corner, but it didn't look like they sold Tube, so I didn't enter.
Secondly, I went to the place in Boronia, which is advertised under two names. He said he could do a special order, but it'd have to be four or eight metres, and he didn't know of anyone who sold DOM in normal lengths.
Now, I don't know what to do. :confused:
take it to a driveshaft joint?
Originally I Telephoned a mob in Bayswater, but he said it was illegal(in a rude manner :confused:). I can't see any mention of Drive/Tail/Prop(Propellor) Shaft on http://vicroads.com.au/
I haven't Telephoned any other Mobs becouse the're too far away. :flamingo:
plenty of places retube driveshafts. make a couple of other calls i think
