what this welder worth
Seattle
long story short a had a guy on craigslist offer me trade for some of my stuff, he has a CK Systematic push-pull Mig 300 Sm welder. Its used and i already have a miller 175 mig welder but he says this ones set up for aluminum. does that meas it just has aluminum wire? Just thought id post it up here and see what you guys think.
I see he has it listed for $1200. Push-pull feeder is good for aluminum. You can have a real long mig gun because the wire is being pushed and pulled. You would be using aluminum mig wire to weld aluminum.
CK Systematic used to make welders for snap on some time ago before Century starting making them.
I don't anything else about CK Systematic.
Here is some info. I found..
From this thread..
http://hobartwelders.com/mboard/showthread.php?t=2474
CK Systematics If I remember right was started by 2 partners making MIG welders and TIG torches. They divided company into CK who makes TIG torches in Seattle and Systematics making welders
Info from welders-ez.com
Systematics Inc.
1025-T Saunders Lane, P.O. Box 2429
West Chester, PA 19380 0125
USA
Tel: 610-696-9040
Or call: 800-222-9353
Assets: 100M+ ($100,000,000 - 249,999,999)
Employees: 50 To 99
Year Company Founded: 1966
Company Description
Welders & Feeders
Links to torch parts for Systematics welders
http://www.usaweld.com/product_page/...ystematic.html
http://www.usaweld.com/product_page/...ts/snapon.html
http://www.americantorchtip.com/migcatalog.html
http://www.americantorchtip.com/pdfC.../MigPage08.pdf
I'm sure someone much more knowlegable will correct me, but I thought all your miller needed was Aluminum wire and whichever gas it needs:confused:
That's what I remember them telling me when I bought my 125
Maybe he just means its CURRENTLY setup for aluminum?
You just need to switch the polarity around, use Argon instead of C25 or C02 and if it's not push/pull you would use a spool gun.
The aluminum wire is really soft, so it's better to pull it from the gun than push it from the machine. I have a Lincoln 125+ 110V machine that claims to be aluminum capable. However, theory and practice are two different things. If I set the wire tension too tight, the wire would birdcage at the machine. If I set the tension loose, the wire feed was not consistent. It was really frustrating to try and weld this way.
