what size socket?
Breckenridge, CO
Does anybody know the size of the nut on the front of a 1971 F engine? I'm refering to the huge nut that I need to turn so I can spin the engine to rotate the clutch. Thanks.
I'm not sure, but I when I was reading about how to adjust valves, someone had mentioned taking out all your plugs and just pulling the alt belt or something. not sure if it works, but i'm sure theres other ways to spin the clutch if you're not sure if you have the right size socket.
Can you get a pipewrench on it?
Otherwise it looks like a 1-3/4" socket will fit.
46mm or 1 3/4 inches.
I used a pipewrench until my 71 engine seized, then I went with the socket.
Where in Minnesota are you? Anywhere close to Farmington?
Ed
Actually I'm in Breckenridge CO right now. When I finish this engine swap up and make sure its working right... I'll be cruising back to MPLS for the summer.
You know you are close to Poser? He is the Bee's Knees about cruisers.
Good Luck with your project!
Ed
