What should compression be w/ 140k?
Vidor, TX
I'm leaving in just a few hours to go buy an 80 assuming it passes my inspection. I'm bringing with me a compression tester, block tester, and an OBII scanner. I know that new it should have 171 psi compression with a max of 30 psi difference between cylinders, but what should I expect on an 1996 80 with 140k miles on it? Also, is there any way to test the lockers? Will I hear them engage? My last 80 didn't have lockers, so I'm not real familiar with this. Any help will be appreciated.
Anyone have a list of the OBDII codes?
what's a "block tester"?
For the lockers, find a dirt parking lot or something. Engaged should be very hard to turn. The lights on the dash should light up solid as well. You may be able to hear it, but might need 2 people, one the outside of the truck and one engaging them inside. Mine is every so faint.
A block tester is great little tool to test for exhaust gases in the coolant system. It's a little tube with a pump that pulls air through a little sponge. You put a little bit this blue liquid in it and put the tip in the opening of the radiator, but don't touch it to the coolant. When the engine gets up to temp, you make a few pumps on it and it pulls in and if it has exhaust gases in the coolant, the blue liquid inside turns yellow and then you know you have a cracked block, cracked head, or blown head gasket. Autozone has it in it's loaner collection.
I tested them and they worked. It was very obvious that they worked and I could hear them engage and the lights came on.
I bought the 80. I do have some concerns though. I did a compression test on it and it was really high. In order 1-6: 188, 188, 185, 177,185, 185. I know it's supposed to be at 171 and with 140k miles, it should be much lower. I also brought with me an IBDII scanner that I got on loan at Autozone as well. On the way home, the engine light came on and I pulled over and plugged in the computer. It was throwing the "P0401 EGR flow insufficient". I erased the code and continued on home. I stopped and got gas after about 30min on the road and when I got back on the road, the engine light came on again. I erased it again. It didn't come back on the rest of the 2 hrs home. This truck was only drive 400 miles in the past year. My theory is that the EGR is screwed and it's creating tons of carbon build-up which is why the compression is so high. Also, the power seats are broken. The driver's seat only adjust the backrest. The passenger's seat goes up and down and the back rest adjust, but the front to back part doesn't work. Anyone in the Houston area want to help me resolve my issues? I can pay with food. lol.
snip
ah, we called those "sniffers"... :)
Congrats!!!:cheers:
If I was in your neighborhood, I'd lend a hand. But alas, I am in Idaho.
Offer :beer::beer::beer: and you may get some takers.;):D
Congrats!!!:cheers:
I don't drink or support drinking or allow alcohol in my home, sorry. My wife is an amazing cook and there's a Papa Johns around the corner.
I can lend you a hand depending on when you want to do them. The items you mentioned are not terribly hard to fix.
Local TLCA chapter Toyota 4x4"s of Texas. T4x4T - Toyota 4x4 of Texas
We are going to have some tech sessions soon. They aren't on the calender yet as wheeling takes priority.
Shoot me an email or pm through mud.
Buck Buchanan
Congrats on the purchase.:cheers:
Forgot to mention, pm Nakman on this site and order 4 white plastic caps and the plastic gears for the seats. I'm 98% sure this will fix your problem and it's cheap. Even if this isn't the issue, it will be at some point.
Buck
I'm pretty sure I need the new caps too. I will be ordering them pronto.
Bukru, thanks for the offer. I will shoot you a PM when I'm getting close. Right now, finals are upon me and I just don't have the time. I also have to get the parts first. Anybody in the Houston area an expert on the EGR system on these things?
Check the other thread.
