What ofther stuff do I need?
CouleeDamWA, BoiseID
Here is what I have for now:
OME851's
OME863's
N70
N71E
OME CC kit
I will be running a 33" tire.
Now with this all put together, what other key items do I need prior to putting on these springs. I mean I wont be able to run to a parts store if something comes up that I should have bought prior to the install. I won't have any other way to get there either.
I know stuff like extended brake lines and sway bar extentions are nice... but are these going to keep me from driving and stopping the truck after the install?
Oh and I need to buy a set of spacers for the front... best item for the dollar?
thanks
FWIW, you might want to get all the suspension installed before you do the caster bushings so that you can have the caster checked and determine if the OME bushings are going to give you enough angle correction. The Slee bushings I have just barely got me back to the bottom of the spec range at 2 deg. With front spacers and the taller rear springs you may need caster plates.
I just did my lift a few weeks ago. I only did shocks and spring in a OME 2.5'"med.
Here is my simple list of what I needed.
19mm Open Wrench (to removed the old shocks), I had to grind my cheap wrench down to make it very thin, the stock nuts on the front were doubled up.
Breaker bar.
17mm Open Wrench
17mm Socket
19mm Socket
12mm Socket
A couple long socket extensions for the rear.
Floor Jack
2 Floor Stand (get good ones!)
1 bottle jack
PB Blaster
Can't think of much else I needed.
I dont know how much harder it will be since you have taller lift. I was able to do almost my entire (first time Ive tried) pretty much by myself. Getting the springs in could be fun if its just you and you can't get the the truck up high enough. Possible may want or a need a spring compressor. I followed Slee's guide and pretty much went just as planned.
Im a totaly rookie, but the above is what got my job done.
Something to grip the old shocks with and some heat to put on the nuts on the shocks....was a PITA to get mine loose (salt free south too)
I ended up cutting that top nut because even with a pipe wrench, PB Blaster, and an impact gun that nut wouldn't move.
Lots of PB blaster, start a couple days before and spray all bolts. Take your time and don't force the nuts and bolts that won't turn. Heat them up, hit them with a hammer, and use lots of PB blaster.
I broke a rear shock bolt and it was a pain in the :censor:.
Every few days Ive been trying to spray PB blaster on the nuts and bolts for the past three weeks. With hopes it wont become a nitemare removing them.
should brake lines, cables, etc. be ok ? what about the shifting of the axles that I read about... do I need to worry about that?
