What is wrong with this picture?
The Rockies or the Andes
So I welded up a new booty fab rocker panel and was adding a 1x1 brace behind it and things just didnt line up right. The body panel over the fender was warping out (first pic). Then I realized (after a suitable number of beers) the body actually changed angles at the joint so i probably needed something similar. This was all rusted out on my 40 so i am kind of making it up as I go along... Thats the second pic, does this look right?
:beer:
Looks fine, are you trying to replicate stock body lines?
Do you use this off road, and if so, why not trim the rock catching steel below the doors?
Yeah I am trying to get fairly close to stock, then I was going to reinforce it and put sliders under it. I guess in a certain sense its a waste of time since I am just going to trash it wheeling but i want it to look as much like a 40 and as little like a "buggy" as possible when I am done.
On the other hand though body work is such a FPITA I am tempted to just chop the body off and... no I can't think about it.
Edit: Actually, the more I look at LC-Hammas setup the more fun that looks to build. Could build the integrated slider from hell...
Well,
Take a few pictures of it all painted up nice, because it will be trashed, and then look like hell, and you will AGAIN be doing fpita body work...only cuttin' off the non-rusted, bent-to-s*** new junk, and trying to come to terms in your head of a balance between too little and too much...
3"x.250 thick angle, welded right to the body, clears the floor support, and I have landed on these many times, with no ill effect.
:beer:
IanB said:
I like it, got any more shots of how you tied it in underneath?
You talkin' to me? ;)
If so,
No I do not. They are not 'tied into' anything other than the side of the body, that is it. Welded right to the sheet metal in about ten spots, rigth at the door seam. Flexiclear body seam sealer where it is not welded, no flakes from beating on them, only some sharp edges that folks have found by running thier hands on the bottom edge to feel how they are mounted.... :doh:
No majik... :)
Good luck!
You talkin' to me?
Obviously, I dun posted mine!
I can't believe your rockers haven't folded under without any rear reinforcing....
You land on them hard at an angle & they will. Have you lifted it with your Hi-lift on those yet?
Land on, and pivot on them, and yes, I have used the high-lift on this 6K+# vehicle, on them...
Not 'playin' with 33's or 36's...
:beer:
