Googled JECS - looks sort of like this doesn't it?:
Function: An essential part of the fuel system, the fuel pressure regulators' sole purpose is to maintain fuel pressure at a constant differential to manifold vacuum under all engine load conditions. The fuel pressure regulator is responsible for controlling the set fuel pressure of the system. Application: Pressure regulators to suit European, Australian and Asian models manufactured by Bosch, JECS and Denso are available from Automotive Service Solutions. We also carry a wide range of regulator rebuild kits to suit throttle body (TBI/CFI) applications. Extensive cross-referencing exists for unusual applications.
Fuel Pumps
Function: Fuel pumps are the heart of the fuel system. A D.C. motor drives a roller cell or gerotor pumping assembly at speeds of up to 10,000 RPM or more. This pumping assembly operates with micron fine tolerances, hence the need to keep the fuel system clean and to keep filters changed regularly. A common application pump generally flows 120-150 litres of fuel an hour at a pressure of approximately 3 bar (45psi) for EFI cars, and up to 5-6 bar (75-90psi) for K-Jetronic systems.
Pumps may be external of the fuel tank (in-line), or a submerged pump inside the fuel tank. Most external fuel pumps also utilise a pre-pump inside the fuel tank to feed the main pump with fuel. In-tank pumps are more common in modern EFI systems due to their cost and noise advantages.
Availability: Automotive Service Solutions supplies pumps from many manufacturers including Bosch, VDO, Nippon Denso, JECS, Walbro and AC Delco. Years of research has allowed us to gather cross reference information for many rare and unusual models as well as the common fast moving applications. Quality is vital with fuel pumps for reliability, don't accept non O.E. quality.
Just a thought.
