What is this thing called?
So. Cal
It's missing a nut and I'd like to see if it has a gasket to replace since I'm in here and it's easy now to get at.
I'm thinking EGR INLET???
It is your egr inlet, there is 2 nuts holding it on. There also is a gasket that goes between it and the manifold. Use antiseize on the nuts for reassembly.
Pull it off and clean it out really well. It can get clogged with carbon on the right side or smaller line to PCV valve.
Thanks, I was actually going to do that but also put it on the manifold bolts...any others that should have it?
I've always wondered if Anti-Seize would cause bolts/nuts to loosen after a while.
It looked like it was leaking from what the picture shows. I wonder what kind of problems it would cause being dirty.
